Minutes/Presentations from various meetings
As of February 2015, the archive for these talks is now located on the
Argonne Box Server
Requires log in.
Hybrid setup
V. Sajaev at 2/12/15 TOM meeting
ID4 orbit Scan on injection efficiency and lifetime
Yipeng Sun at 2/12/15 TOM meeting
Physical Aperture Measurements of ID4
L. Emery at 2/12/15 TOM meeting
SR injection efficiency problem
C-Y Yao at 2/12/15 TOM meeting
Study SummaryAPS Start Up 2015-1
K. Harkay at 2/5/15 TOM meeting
Study Summary APS Start Up
A. Xiao at 2/5/15 TOM meeting
RF Gun Issues Jan. 2015 Start-Up
Yin-E Sun at 2/5/15 TOM meeting
SR Studies Plan
L. Emery at 12/4/14 TOM meeting
Injection bump study
Yipeng Sun at 11/13/14 TOM meeting
More Local Impedance Measurements
L. Emery at the 11/13/14 TOM meeting
ID1 BLM Injection Loss Measurements
J. Dooling at 11/13/14 TOM meeting
PAR charge study
C-Y Yao at 11/13/14 TOM meeting
Obrit switch
A. Xiao at 11/13/14 TOM meeting
Study report
A. Xiao at 10/23/14 TOM meeting
Study Summary: Investigation of P0 feedback related Beam Instability
C-Y Yao at 10/23/14 TOM meeting
Hybrid Bunch Pattern Lifetime Checkout
L. Emery at 10/23/14 TOM meeting
ID1 BLM studies: calibration with beam using IK1 after moving the BLM to the downstream ID
J. Dooling at 10/23/14 TOM meeting
ID1 beam loss monitor studies: calibration & beam dumps. Single bunch - 100 mA, 24 singlets
J. Dooling at 10/2/14 TOM meeting
SCU0 chamber vertical re-alignment result
K. Harkay at 10/2/14 TOM meeting
Study Summary
A. Xiao at 10/2/14 TOM meeting
Some Start Up Notes
L. Emery at 10/2/14 TOM meeting
Coupled Bunch Instabilities with Landau Cavities
L. Emery at 6/24/14 TOM meeting
Investigation of tune change.
L. Emery at 6/17/14 TOM meeting
Study summary
C-Y Yao at 6/17/14 TOM meeting
SCU0 BLM & IK5 pinger studies
K. Harkay at 6/17/14 TOM meeting
RTFB and datapool studies
L. Emery w/ Sereno, Arnold and Carwardine at 6/5/14 TOM meeting
Machine Study Report (Orbit Recovery CPU & IEX Check Up
A. Xiao at 5/29/14 TOM meeting
Start-up Studies 2014/05
V. Sajaev at 5/29/14 TOM meeting
SCU0 BLM studies
J. Dooling and K. Harkay at 3/18/14 TOM meeting
SCU0 beam losses during beam dumps with ID28 bump using FO BLM
J. Dooling at 1/23/14 TOM meeting
Fast pressure diagnostic for the SR
J. Dooling at 1/9/14 Physics meeting
Vertical Beamsize Control and Measurements
L. Emery, V. Sajaev & A. Xiao at the 1/24/14 TOM meeting
Machine studies: Runs 2013-3, 2014-1
K. Harkay at the 1/24/14 TOM meeting
H7BA Injection/Extraction Design
A. Xiao at 12/12/13 Physics meeting
Study Summary - 2013/11/28 and 2013/12/4
by A. Xiao at 12/4/13 meeting
Studies 2013/12/03 Optics correction using TBT - continuation
V. Sajaev at 12/4/13 meeting
Studies 2013/11/12 Injection optimization program development
V. Sajaev at 11/20/13 meeting
Studies 2013/11/18 Optics correction using turn-by-turn
Booster septum aperture scan with SR on-axis injection
by L. Emery at 11/21/2103 TOM meeting
Booster 132-nm lattice tune-up
C-Y Yao at the 11-20-13 meeting
Attempts to make 100% efficiency in On-axis injection
Louis Emery at the 11-14-13 meeting
High Coupling Injection
by A. Xiao at 11/14/2013 TOM
OAGapps Gnome Menu
by H. Shang at 11/14/2013 TOM meeting
Injection into Small Aperture
Louis Emery and Yipeng Sun at the 11-5-13 meeting
Accumulation Limit and Injection into Small Aperture
Louis Emery, Ryan Lindberg and Yipeng Sun at the 10-30-13 meeting
SR Studies on accumulation limit
L. Emery and R. Lindberg at 10-22-13 meeting
Accumulation Limit In Reference Orbit Lattice
Louis Emery and Ryan Lindberg at the 10-24-13 meeting
Louis Emery and Yipeng Sun at the 10-17-13 meeting
Injection into Small Aperture and Accumulation Limit In Reference Orbit Lattice
Louis Emery, Yipeng Sun and Ryan Lindberg at the 10-10-13 meeting
Problem with S21C:BM SR studies
L. Emery and R. Lindberg at 9-30-13 meeting
Small aperture injection, single bunch limit
L. Emery at 10-10-13 meeting
High charge PAR and booster studies
CY Yao at 10-10-13 meeting
Coupling correction
C-X Wang at 8-13-13 TOM meeting.
SCU0 Quench Studies
K. Harkay at 8-8-13 TOM meeting
SCU0 Quench Investigation
K. Harkay and L. Emery at 8-1-13 TOM meeting
Accumulation limit measurement on reference orbit
Louis Emery and Ryan Lindberg at 7-16-13 TOM meeting
Tutorial on rf gap voltage controllawt
Louis Emery at 7-16-13 meeting
Decoherence
C-X Wang at 7-9-13 TOM meeting.
FPGA BPM Waveform Data Collection Speed Test
Hairong Shang at 4-11-13 TOM meeting.
Interleaving to Support FEL/Fourth Generation Light Source
Jeff Dooling at the 3-21-13 Physics meeting.
Mode-locked hard x-ray pulse trains
Ryan Lindberg at the 3-7-13 Physics meeting.
MIA optics measurement and correction of APS ring
C-X Wang at the 2-7-13 meeting.
Electromagnetic Simulation of Fermilab's S-band SPX Cavity
Yong-Chul Chae at 1-24-13 meeting.
SCU0 Status and Beam Heating
K. Harkay at the 2-28-13 TOM meeting.
Application of Z-Transform to Noise Response Modeling of a Bunch-by-Bunch Feedback System
C-Y Yao at 2-14-13 meeting
SCU0 Commissioning Plan & Operations
Katherine Harkay at the 1-10-13 meeting
IDChamberOptimization
Yong-chul Chae at 10-11-2012 TOM meeting
S37Development_MARS_HOM
Yong-chul Chae at 4-26-2012 TOM meeting
Dihedral Group and Repetitive Achromats with Mirror Symmetric or Mirror Antisymmetric Basic Cell
C-X Wang at AOP physics meeting
Modeling of Booster Chromaticity Time Variation
C-Y Yao at the 2/23/12 meeting
Linac Three-Screen Emittance Measurement Analysis
Jeff Dooling at the 2/16/12 meeting
Fitting Coherent Damping Rate From pinging-method Data
C-Y Yao
APS Storage Ring Phase Noise Studies Using P5 FPGA BPMs, an S-Band Phase Detector and elegant Simulation
Nick Sereno
Studies Summary, Run 2011-2 Monitoring Beam Dumps
Jeff Dooling at the 9-15-11 meeting
Run 2011-2 studies summary
Katherine Harkay at the 9-8-11 meeting
Vadim Sajaev at the 9-1-11 meeting
Low workfunction photocathodes
Zsolt Terdik 9-2-2011
Run 2011-1 Injector Studies Summary Run
Nick Sereno at the 9-1-11 meeting
Machine Study on Slow Beam Dump
Yong-Chul Chae at the 9-1-11 meeting
Multibunch vs. single bunch instability thresholds
Katherine Harkay at the 7-7-11 meeting
Model Independent Analysis Study at APS
Daheng Ji at the 6-9-11 meeting
Design Studies on Ultra-Low-Emittance Injector for X-ray FEL Oscillator
Xiaowei Dong at the 6-6-11 meeting.
Injection studies
Vadim Sajaev at the 1-13-11 meating
HOMs and component heating with high current in the storage ring
Katherine Harkay at the 12-2-10 meeting
Dynamic aperture increase by symmetry breaking
Vadim Sajaev at the 4-8-10 meeting.
Photocathode R&D at Argonne
Katherine Harkay at the 2-25-10 meeting
Extra slides for Photocathode R&D
Feasibility Study of Very Low Emittance Storage Rings at SPring-8
Lee Teng at the 2-4-10 meeting
Gas bremsstrahlung radiation modeling with MARS
Jeff Dooling at the 2-4-10 meeting
Pulsed multipole injection
V. Sajaev at the 09-10-09 meeting
Minimum emittance in storage rings with uniform or nonuniform dipoles
C-X Wang at the 09-03-09 meeting
S. Pasky reporting on "Power Saving Schemes in the NSRRC3"
(PAC09 report)
L. Emery reporting on "Multiobjective Light Source Lattice Optimization,"
L. Yang, D. Robin, F. Sannibale, C. Steier, W. Wan (PAC09 report)
C-Y Yao reporting on "Stored Beam Stability During Pulsed Sextupole Injection at the Photon Factory SR"
H. Takaki, N. Nakamura, Y. Kobayashi, K. Harada, T. Miyajima, A. Ueda, S. Nagahashi, M. Shimada, T. Honda, T. Obina (PAC09 report)
Fiber Optic Beam Loss Position Monitor -a work in progress
   Jeff Dooling's talk at the 4-2-09 meeting
VIIth Fast Timing Workshop The Development of Large-Area picosecond Photo-Devices
   Marion White's talk at the 3-26-09 meeting
Highlights from A0 photoinjector workshop
   Katherine Harkay's talk at the 3-11-09 meeting
Integrated Solution for XFEL-O Linac and Recirculation System
   Michael Borland's talk at the 2-19-09 meeting
Corrections of Perturbations of Circularly Polarizing Undulator
   Louis Emery's talk at the 2-12-09 meeting
X-ray FEL Performance with the 7-GeV Superconducting RF Linac
   Yong-Chul Chae's talk at the 12-04-08 meeting
Links can only be viewed from inside the APS domain.
