Gap Thresholds for in-use X-ray BPMs Listed below are the gap position thresholds for X-ray BPMs, above which the X-ray BPM signals may not be strong enough to give accurate readings or orbit disturbances have occurred in the past. Although the X-ray BPMs remain in the configuration, the gain is set to zero which removes their input from orbit control during the time the gap position is above the threshold. If a sector has two undulators and is not canted, an additional requirement of one undulator gap position remaining fixed or both undulators having the the same gap position exists. Canted beamlines can move their undulators independently and each undulator has its own threshold.
Sector No. |
Threshold in mm |
Additional Requirements |
1 |
25.0 for US |
Downstream undulator must be at 180mm ±0.1mm |
25.0 for DS |
Upstream undulator must be at 180mm ±0.1mm |
2 |
31.0 |
X-ray BPMs not used because the two undulators move to any combination of gap postions |
3 |
31.0 |
Both undulators must be at the same gap position ±0.5mm |
4 |
31.0 |
X-ray BPMs not used because CPU in upstream location |
5 |
31.0 |
6 |
31.0 |
X-ray BPMs not used because SCU0 is in downstream location |
7 |
31.0 |
8 |
31.0 |
9 |
25.0 |
Upstream gap position must be at 180mm ±0.1mm |
10 |
31.0 |
11 |
25.0 |
Downstream gap must be at 10.7mm ±0.1mm |
12 |
28.0 for US |
31.0 for DS |
13 |
31.0 for US |
31.0 for DS |
14 |
25.0 |
Downstream undulator must be at 10.78mm ±0.1mm |
15 |
31.0 |
16 |
28.0 for US |
28.0 for DS |
17 |
31.0 |
18 |
31.0 |
19 |
30.0 |
20 |
31.0 |
21 |
25.0 for US |
25.0 for DS |
22 |
24.0 |
23 |
31.0 for US |
31.0 for DS |
24 |
31.0 for US |
26.0 for DS |
26 |
31.0 |
27 |
31.0 |
Grid X-ray BPMs are currently not in orbit correction |
30 |
31.0 |
31 |
25.0 |
32 |
29.0 |
33 |
31.0 |
34 |
31.0 for US |
31.0 for DS |
