sddswmonitor reads values of waveform process variables
and writes them to a file at a specified time interval.
An input file defines the process variables to be monitored.
Warning: If the readback values of all of the waveform PVs do not change, then no data sets are written to the output file. This skipping of duplicate values is intended to keep the size of the output file as small as possible. The scalar PVs are not checked for changes though. In the future an option that allows logging of duplicate waveform PVs may be implemented.
sddswmonitor SlowBh.wmon SlowBh.sdds -step=1where the contents of the file
SlowBh.wmon are
SDDS1 &description &end &description contents = "sddssequence output", &end ¶meter name = WaveformLength, type=long, &end &column name = WaveformPV, type = string, &end &column name = WaveformName, type = string, &end &data mode = ascii, &end ! page number 1 512 ! WaveformLength 2 ! number of rows S1A:P1:bh:x_wf S1A:P1:x S1A:P1:bh:y_wf S1A:P1:y
usage: sddswmonitor {<inputfile> | -PVnames=<name>[,<name>]} <outputfile>
[{-erase | -generations[=digits=<integer>][,delimiter=<string>]}]
[-steps=<integer> | -time=<value>[,<units>]] [-interval=<value>[,<units>]]
[-verbose] [-singleShot[=noprompt]] [-precision={single | double}]
[-onCAerror={useZero | skipPage | exit}]
[-scalars=<filename>]
[-conditions=<filename>,{allMustPass | oneMustPass}[,touchOutput][,retakeStep]]
[-ezcaTime=<timeout>,<retries>]
[-comment=<parameterName>,<text>]
Writes values of waveform process variables to a binary SDDS file.
The input file is an SDDS file with two required columns and one required parameter:
WaveformLength -- Required long parameter for the length of the waveform PV's. All
WaveformPVs are expected to have this length.
WaveformPV -- Required string column for the names of the waveform process variables.
WaveformName -- Required string column for the names of the data columns in the output file.
An optional input file for scalar PVs (i.e. regular PVs) can be specified. The required columns are:
The conditions file is an optional input file specified on the command line which lists conditions that must be satisfied at each time step before the data can be logged.
The file is like the main input file, but has numerical columns LowerLimit and UpperLimit.
The minimal column set is ControlName, which contain the PV names, and the two limits columns above.
Depending on comand line options, when any or all PV readback from this file
is outstide the range defined by the corresponding data from LowerLimit and UpperLimit,
none of the data of the input file PVs are recorded.
When this situations occurs for a long period of time, the size of the output file doesn't
grow, and it may appear that the monitoring process has somehow stopped.
It is possible to check the program activity with the touch sub-option
which causes the monitoring program to touch the output file at every step.
The output file contains one data column for each waveform process variable named in the input file. The names
of the data columns are given by the values of WaveformName in the input file. The units are obtained
internally from the EPICS database. An additional long column Index is created that give the index
of each point in the waveform.
The values of the scalar PVs are written to parameters with names given by the ReadbackName column of the optional scalars input file. The units are obtained internally from the EPICS database.
By default, the data type is float (single precision). Each reading step produces a new page in the output file.
Time and other miscellaneous parameters are defined:
For each scalar PV defined in the scalars command line option a parameter of type double is defined.
Many additional parameters which don't change values throughout the file are defined:
StartYear -- Short parameter for the year when the file was started.
StartJulianDay -- Short parameter for the day when the file was started.
StartMonth -- Short parameter for the month when the file was started.
StartDayOfMonth -- Short parameter for the day of month when the file was started.
StartHour -- Short parameter for the hour when the file was started.
-PVnames=<name>[,<name>] --
specifies a list of PV names to read. It the waveforms are
of different lengths, the short ones are padded with zeros.
sddswmonitor.
-generations[=digits=<integer>][,delimiter=<string>] --
The output is sent to the file <SDDSoutputfile>-<N>, where <N> is
the smallest positive integer such that the file does not already
exist. By default, four digits are used for formating <N>, so that
the first generation number is 0001.
-singleShot[=noprompt] -- a single read is prompted at the terminal
and initiated by a <cr> key press. The time interval is disabled.
With noprompt present, no prompt is written to the terminal, but a <cr>
is still expected. Typing ``q'' or ``Q'' terminates the monitoring.
-conditions=<filename>,{allMustPass | oneMustPass}[,touchOutput][,retakeStep]] --
Names an SDDS file containing PVs to read and limits on each PV that must
be satisfied for data to be taken and logged. The file is like the main
One of allMustPass or oneMustPass must be specified. It would make sense
to use allMustPass in most monitoring applications.
If touchOutput is present, then the output file is touched, even if no data
is written. This way, one can determine by the time stamp of the file
whether the monitoring job is still alive
when the conditions fail for a long period of time. If retakeStep is
present, then the value of Step in the output file is not
incremented until the conditions pass, and data is written to the output file.
-comment=<parameterName>,<text> --
Gives the parameter name for a comment to be placed in the SDDS output file,
along with the text to be placed in the file.
