Next: Toolkit Program Usage Conventions
Up: EPICS Toolkit Programs by
Previous: Data Collecting
  Contents
- sddscontrollaw -- Reads a matrix for a control law-type equation and regulates the
values of a list of readback process variables by applying corrections to another list of process variables.
Example application: removing slow drifts in accelerators (such as the energy of a linac beam), trajectory
and orbit correction.
- knobconfig -- Assigns knobs to devices according to the input file.
Example application: Manually tweak a trajectory, storage ring tunes and chromaticity.
- squishPVs -- Minimizes the absolute values of a set of readback process variables
by varying setpoint process variables which have a physical influence on the readback process variables.
Example application: Reducing the size of the trajectory in a beamline without knowledge of the
response matrix between bpms and correctors.
- sddsoptimize --Minimizes or maximizes the RMS of a set of readback process variables by automatically varying setpoint process variables (or knobs composed of setpoint PVs), which have a physical influence on the readback process variables, through simplex or 1dscan method.
- sddspvtest --tests the process variable given by the inputfile are out-of-range or not and sets the number of out-of-range process variables to a control PV.
  Contents
Hairong Shang
2002-02-06
