Next: Graphics Tools
Up: SDDS Toolkit Programs by
Previous: Data Fitting Tools
  Contents
- sddsbreak -- Breaks data pages into new, separate pages based on changes in column data and other
criterion. Example applications: reorganizing a file to have a limited number of rows in each page, or to have a
new page started when a gap is seen in the data.
- sddscollapse -- Collapses a data set into a single data page by deleting the tabular data and
turning the parameters into columns. Example application: abstraction of summary properties of data set following
analysis with
sddsprocess.
- sddscollect -- Reorganizes tabular data from the
input file to bring data from several groups of similarly named
columns together into a single column per group. Example application:
collecting several statistical analyses of many columns into a single
column per analysis type.
- sddscombine -- Combines any number of data sets into a single data set by adding data from each
successive data set to a newly-created data set. Example application: bringing together comparable but distinct
data for analysis with
sddsprocess. Using sddsprocess, sddscombine, and sddscollapse
in sequence repeatedly is a powerful way to analyze and collate large amounts of data.
- sddsconvert -- Allows conversion of a data set between binary and ASCII, with optional deletion
and renaming of columns, arrays, and parameters . Example application: conversion to binary of an ASCII data set
created by a simple program, or by a text editor.
- sddsderef -- Allows dereferencing (i.e., de-indexing) of array and column data. Example
application: converting a column of integer indexes into a column of equivalent text messages, where the text
messages are stored once each in an array in the input file (for space-savings).
- sddsendian -- Converts from little-endian to
big-endian and vice-versa. Example application: converting binary
data from the native format to a format used on another type of
computer prior to transferring the data to the other computer.
- sddsexpand -- Expands a data set into one page for each row, with column data promoted
to parameter data. Essentially the inverse of sddscollapse.
- sddsregroup -- Swaps the row indexing and page
indexing of data in an SDDS file. That is, the
row of
the
data page in the input file becomes the
row of the
data page of the output file.
Example application: viewing the long-term evolution of a
repeatedly-sampled waveform at each point in the waveform.
- sddstranspose -- Transposes the tabular data in the
input file, so that the output file contains one column for each row
in the input. Example usage: tranpose an orbit response matrix as
part of preparing to use it for feedback.
- sddsmatrixmult -- Multiplies the tabular data in the
two input files to produce a file containing a matrix of the product.
Example usage: Multiply a vector of errors with a correction matrix to
obtain a vector of corrections to apply in a step-by-step feedback
system.
- sddsselect -- Copies rows from one file based on the
presence or absence of matching data in another file. Example
application: finding all of the rows from one file that do not appear
in a second file.
- sddssort -- Sorts the tabular data section of a data set by the values in named columns.
Optionally eliminates duplicate rows.
- sddssplit -- Places each page of a file in a separate, new file. Example application: getting
selected pages of a file into separate, single-page files for use with a program that only recognizes the first
page.
- sddsxref -- Creates a new data set by adding selected
rows from one data set to another data set. Example application:
cross-referencing the turn-by-turn coordinates of particles in a
tracking simulation with the initial coordinates using a particle ID
number.
  Contents
Louis Emery
2000-09-15
