Next: Toolkit Program Usage Conventions
Up: SDDS Toolkit Programs by
Previous: File Protocol Conversion Tools
  Contents
- sdds2stream -- Takes column or parameter data from a list of SDDS data sets and delivers it to
the standard output as a stream of values. Example application: getting data into a shell variable for use in a
script.
sdds2stream may be used to convert SDDS data to plain ASCII text.
- sddsprintout -- Makes customized printouts from
column, parameter, and array data in an SDDS data set. Also makes
spreadsheet-compatible data and plain ASCII text. Example
application: making a nicely-formatted printout of data that needs to
be reviewed manually.
- sddsquery -- Prints a summary of the SDDS header for a data set. Also prints bare lists of names
of defined entities, suitable to use with shell scripts that need to detect the existence of entities in the data
set.
Robert Soliday
2001-05-21
