sddstranspose views the numerical tabular data of the input file
as though it formed a matrix, and produces an output
file with data corresponding to the transpose of the input
file matrix. In other words, the columns of tabular data of the input
file become rows in the output file. String column data
are not transposed but are stored as string parameters in the output file.
Operating on the output file with a second sddstranpose command essentially recovers
the original input file.
The column names for the output file are generated either from the data in a selected string column in the input file, from the value of the command line option -root, or from an internal default.
The column names of the input file are collected and made into a string column in the output file.
