- description:
sddszerofind finds the locations of zeroes in a single column of an SDDS file. This is done by finding successive rows
for which a sign change occurs in the ``dependent column'', or any row for which an exact zero is present in this column. For
each of the ``independent columns'', the location of the zero is determined by linear interpolation. Hence, the program
is really interpolating multiple columns at locations of zeros in a single column. This single column is in a sense
being looked at as a function of each of the interpolated columns.
- examples:
Find zeroes of a Bessel function,
sddszerofind J0.sdds J0.zero -zero=J0 -column=z
, and simultaneously interpolate
at
the zero locations:
sddszerofind J0.sdds J0.zero -zero=J0 -column=z,J1
(This isn't the most accurate way to interpolate
, of course.)
- synopsis:
sddszerofind [-pipe=[input][,output]] [inputfile] [outputfile]
-zeroesOf=columnName [-columns=columnNames] [-slopeOutput]
- files:
inputFile contains the data to be searched for zeroes. outputFile contains columns for each of the independent
quantities and a column for the dependent quantity. Normally, each dependent quantity is represented by a single column of
the same name. If output of slopes is requested, additional columns will be present, having names of the form
columnNameSlope.
If inputFile contains multiple pages, each is treated separately and is delivered to a separate page of outputFile.
- switches:
-pipe[=input][,output] -- The standard SDDS Toolkit pipe option.
- -zeroesOf=columnName -- Specifies the name of the dependent quantity, for which zeroes
will be found.
- -columns=columnNames -- Specifies the names of the independent quantities, for which
zero locations will be interpolated. Generally, there is only one of these. columnNames
is a comma-separated list of optionally wildcarded names.
- -slopeOutput -- Specifies that additional columns will be created containing the slopes of
the dependent quantity as a function of each independent quantity. This can be useful, for example,
if one wants to pick out only positive-going zero-crossings.
- see also:
- author: M. Borland, ANL/APS.
