mpl data files to an SDDS data set. mpl is a simple data format used by the
mpl Toolkit, which is now largely superseded by SDDS and will not be supported in the future.
mpl data file to the data set. However, a column that has the same name as an existing column
will not be used. By default, the data in the mpl files is added to SDDSFile, if it
exists already.
-erase -- Specifies that if SDDSFile exists already, it should be
erased prior to adding any data to the data set. By default, the data in SDDSFilename
is retained.
