elegant2genesis analyzes particle output data from elegant and prepares
a ``beamfile'' for input to GENESIS[8], a 3-D time-dependent FEL code by
S. Reiche. The beamfile is contains slice analysis of the particle data, and may be
useful in other applications as well.
elegant or any other program that
uses the same column names and units.
-pipe[in][,out] -- The standard SDDS toolkit pipe option.
-textOutput -- Requests text output instead of SDDS output, which may be
useful for input to non-SDDS-complaint versions of GENESIS.
-totalCharge=coulombs -- Gives the total charge of the beam in Coulombs.
-chargeParameter=name -- Gives the name of a parameter in inputfile where
the total charge in the beam is given.
-wavelength=meters -- This option is misnamed. It is actually the slice length
in meters.
-slices=integer -- The number of analysis slices to use.
-steer -- If given, then the transverse centroids for the bulk beam are all set to
zero. The relative centroid offsets of the slices are, of course, unchanged.
removePTails=deltaLimit=value[,fit][,beamOutput={\em filename}\verb]| --
Remvoes the momentum tails from the beam. deltaLimit is the maximum absolute value
of
fit is given,
then a linear fit to beamOutput is given, then the filtered beam data is
written to the named file for review.
