sdds2spreadsheet converts an SDDS file to a file that can be read into most spreadsheet programs.
You need to consult your particular spreadsheet program to see how it reads ASCII files. For Wingz, the
conversion is automatic. Excel 5.0 will bring up its Text Import Wizard.
Notes:
\t.
sddsprintout with the -spreadSheet
option is intended to replace the function of sdds2spreadsheet.
It allows greater control of what data is output and how it is
formatted.
pipe -- The standard SDDS Toolkit pipe option.
delimiter -- Delimiter string (Default is "").
all -- Write parameter, column, and array information.
(Default is data and parameters only)
verbose -- Write header information to the terminal like sddsquery.
