&description
STRING text = NULL
STRING contents = NULL
&end
This optional command describes the data set in terms of two strings. The first, text, is an informal description that is intended principly for human consumption. The second, contents, is intended to formally specify the type of data stored in a data set. Most frequently, the contents field is used to record the name of the program that created or most recently modified the file.
Example:
&description
text = "Twiss parameters for APS lattice",
contents = "Twiss parameters"
&end
Note: In many cases it is best to use a string parameter for descriptive text instead of the description command. The reason is that the Toolkit programs will allow manipulation of a string parameter.
