sddsderef allows array and column dereferencing based on constants
or on data in parameters and columns.
arrayData be a file containing a string array named
MessageText
and a column named MessageIndex containing integers.
The integers are indices into the string array. To create a new column
called Message giving the message text for each index, the
following command would be used:
