examples:
sddsmakedataset mydata.sdds -parameter=pi,type=double -data=3.1415926 -parameter=UserName,type=string -data=somebody
-column=index,type=short -data=1,2,3,4,5,6,7,8,9,10 -column=primeNumbers,type=long -data=1,2,3,5,7,11,13,17,19,23
-column=lettersOfAlphabet,type=character -data=a,b,c,d,e,f,g,h,i,j -ascii
An ascii file mydata.sdds is created by this command. The printout of mydata.sdds is as following: (used sddsprintout to get the prinout).
Printout for SDDS file mydata.sdds
pi = 3.141593e+00 UserName = somebody
index primeNumbers lettersOfAlphabet
1 1 a
2 2 b
3 3 c
4 5 d
5 7 e
6 11 f
7 13 g
8 17 h
9 19 i
10 23 j
synopsis:
sddsmakedataset [<oututFile> | -pipe=out]
[-defaultType=double|float|long|short|string|character] [-parameter=<name>[,type=<string>][,units=<string>][,symbol=<string>][,description=<string>]]
[-data=<value>] -parameter=.... -data=...
[-column=<name>[,type=<string>][,units=<string>][,symbol=<string>][,description=<string>]]
[-data=<listOfCommaSeparatedValue>] -column=... -data=...
[-noWarnings] [-description=<string>] [-contents=<string>] [-mode=<string>]
