Next: save_lattice
Up: Namelist Command Dictionary
Previous: run_setup
- type: setup/action command.
- function: set parameters for computation of SASE FEL gain and other properties.
&sasefel
STRING output = NULL;
STRING model = "Ming Xie";
double beta = 0;
double undulator_K = 3.1;
double undulator_period = 0.033;
double slice_fraction = 0.0;
long n_slices = 0;
&end
output -- The (incomplete) filename of an SDDS file to which output will be
written.
model -- The name of the FEL model used. At present, only one model is
supported; the ``Ming-Xie'' model is based on the simple parametrization M. Xie[12].
beta -- The value of the beta function, in meters.
undulator_K -- The K parameter of the undulator.
undulator_period -- The undulator period, in meters.
slice_fraction, n_slices -- The fraction of beam beam contained by each analysis slice
and the number of such slices.
By default, no slice analysis is done. Instead, the beam is analyzed only as a whole.
If slice_fraction*n_slices is less than 1, then the slice analysis
is centered on the median of the time distribution. E.g., if n_slices=1 and
slice_fraction=0.1, then the central 10% of the beam would be analyzed.
More typically, one gives values such that slice_fraction*n_slices is
equal to 1, so that every part of the beam is analyzed. There are separate values in
the output file for each slice, plus the whole-beam and slice-averaged results.
Next: save_lattice
Previous: run_setup
Michael Borland
2001-06-08
