As mentioned in the introduction, elegant uses a variant of the MAD input format for describing accelerators. With some exceptions, the accelerator description for one program can be read by the other with no modification. Among the differences:
link_element
namelist command
can be used for this purpose, and is actually more flexible than the
method used by MAD. Also, rpn
-style equations may be given
in double-quotes; these are evaluated once only when the lattice
is parsed.
elegant's print_dictionary
command allows the user to
obtain a list of names and short descriptions of all accelerator
elements recognized by the program, along with the names, units,
types, and default values of all parameters of each element.
The present output of this command is listed in the next section.
The reader is referred to the MAD manual[2] for details on sign
conventions for angles, focusing strength, and so forth.
