Next: closed_orbit
Up: Namelist Command Dictionary
Previous: bunched_beam
- type: setup command.
- function: set up for chromaticity correction.
&chromaticity
STRING sextupoles = NULL;
double dnux_dp = 0;
double dnuy_dp = 0;
double sextupole_tweek = 1e-3;
double correction_fraction = 0.9;
long n_iterations = 5;
double tolerance = 0;
STRING strength_log = NULL;
long change_defined_values = 0;
double strength_limit = 0;
long use_perturbed_matrix = 0;
&end
sextupoles -- List of names of elements to use to correct the chromaticities.
dnux_dp, dnuy_dp -- Desired chromaticity values.
sextupole_tweek -- Amount by which to tweak the sextupoles to compute derivatives of
chromaticities with respect to sextupole strength. [The word ``tweak'' is misspelled ``tweek'' in the code.]
correction_fraction -- Fraction of the correction to apply at each iteration. In some
cases, correction is unstable at this number should be reduced.
n_iterations -- Number of iterations of the correction to perform.
tolerance -- Stop iterating when chromaticities are within this value of the
desired values.
strength_log -- The (incomplete) name of an SDDS file to which the sextupole strengths will
be written. Recommended value: ``%s.ssl''.
change_defined_values -- Changes the defined values of the sextupole strengths.
This means that when the lattice is saved (using save_lattice), the sextupoles will
have the corrected values. This would be used for correcting the chromaticity of a design
lattice, for example, but not for correcting chromaticity of a perturbed lattice.
strength_limit -- Limit on the absolute value of sextupole strength (
use_perturbed_matrix -- If nonzero, requests use of the perturbed correction matrix in
performing correction. For difficult lattices with large errors, this may be necessary
to obtain correction. In general, it is not necessary and only slows the simulation.
Next: closed_orbit
Michael Borland
2001-06-08
