| Parameter Name | Units | Type | Default | Description |
| L | double | 0.0 | length | |
| CELL_LENGTH | double | 0.0 | cell length (used to scale wakes) | |
| VOLT | double | 0.0 | voltage | |
| PHASE | double | 0.0 | phase | |
| FREQ | double | 500000000 | frequency | |
| Q | double | 0.0 | cavity Q | |
| PHASE_REFERENCE | long | 0 |
phase reference number (to link with other time-dependent elements) | |
| CHANGE_P0 | long | 0 |
does element change central momentum? | |
| CHANGE_T | long | 0 |
not recommended | |
| FIDUCIAL | STRING | NULL | mode for determining fiducial arrival time (light, tmean, first, pmaximum) | |
| END1_FOCUS | long | 0 |
include focusing at entrance? | |
| END2_FOCUS | long | 0 |
include focusing at exit? | |
| BODY_FOCUS_MODEL | STRING | NULL | None (default) or SRS (simplified Rosenzweig/Serafini for standing wave) | |
| N_KICKS | long | 1 | number of kicks to use. Set to zero for matrix method. | |
| WAKEFILE | STRING | NULL | name of file containing Green functions | |
| ZWAKEFILE | STRING | NULL | if WAKEFILE=NULL, optional name of file containing longitudinal Green function | |
| TRWAKEFILE | STRING | NULL | if WAKEFILE=NULL, optional name of file containing transverse Green functions | |
| TCOLUMN | STRING | NULL | column containing time data | |
| WXCOLUMN | STRING | NULL | column containing x Green function | |
| WYCOLUMN | STRING | NULL | column containing y Green function |
A combination of RFCA, WAKE, and TRWAKE.
| WZCOLUMN | STRING | NULL | column containing longitudinal Green function | |
| N_BINS | long | 0 |
number of bins for current histogram | |
| INTERPOLATE | long | 0 |
interpolate wake? | |
| SMOOTHING | long | 0 |
smooth current histogram? | |
| SG_HALFWIDTH | long | 4 | Savitzky-Golay filter half-width for smoothing | |
| SG_ORDER | long | 1 | Savitzky-Golay filter order for smoothing | |
| DX | double | 0.0 | misalignment | |
| DY | double | 0.0 | misalignment |
