| Parameter Name |
Units |
Type |
Default |
Description |
| RA |
double |
0.0 |
shunt impedance |
| RS |
double |
0.0 |
shunt impedance (Ra=2*Rs) |
| Q |
double |
0.0 |
cavity Q |
| FREQ |
double |
0.0 |
frequency |
| CHARGE |
double |
0.0 |
beam charge (or use CHARGE element) |
| INITIAL_V |
double |
0.0 |
initial voltage |
| INITIAL_PHASE |
double |
0.0 |
initial phase |
| INITIAL_T |
double |
0.0 |
time at which INITIAL_V and INITIAL_PHASE held |
| BETA |
double |
0.0 |
normalized load impedance |
| BIN_SIZE |
double |
0.0 |
bin size for current histogram (use 0 for autosize) |
| N_BINS |
long |
20 |
number of bins for current histogram |
| PRELOAD |
long |
0 |
preload cavity with steady-state field |
| PRELOAD_FACTOR |
double |
1 |
multiply preloaded field by this value |
| RIGID_UNTIL_PASS |
long |
0 |
don't affect the beam until this pass |
| SAMPLE_INTERVAL |
long |
1 |
passes between output to RECORD file |
| RECORD |
STRING |
NULL |
output file for cavity fields |
| SINGLE_PASS |
long |
0 |
if nonzero, don't accumulate field from pass to pass |
| PASS_INTERVAL |
long |
1 |
interval in passes at which to apply PASS_INTERVAL times the field (may increase speed) |
