Next: floor_coordinates
 Up: Namelist Command Dictionary
 Previous: error_control
- type: action command.
- function: find the aperture in (x, y) space for an accelerator.
&find_aperture
    STRING output = NULL;
    STRING boundary = NULL;
    STRING mode = "many-particle";
    double xmin = -0.1;
    double xmax =  0.1;
    double ymin =  0.0;
    double ymax =  0.1;
    long nx  = 21;
    long ny  = 11;
    long n_splits = 0;
    double split_fraction = 0.5;
    double desired_resolution = 0.01;
    long verbosity = 0;
    long assume_nonincreasing = 0;
&end
output -- The (incomplete) name of an SDDS file to send output to.
 Recommended value: ``%s.aper''.
boundary -- The (incomplete) name of an SDDS
file for the boundary points of the aperture search.  Recommended value: ``%s.bnd''.
xmin, xmax, ymin, ymax -- Region of the aperture search.
mode -- May be ``many-particle'' or ``single-particle''.  Many-particle searching is
much faster, but does not allow interval splitting to search for the aperture boundary.
nx -- Number of x values to take in initial search.
ny -- Number of y values to take in search.
n_splits -- If positive, the number of times to do interval splitting.  Interval splitting
refers to searching between the original grid points in order to refine the results.
split_fraction -- If interval splitting is done, how the interval is split.
desired_resolution -- If interval splitting is done, fraction of xmax-xmin to which to resolve the aperture.
assume_nonincreasing -- If this variable is non-zero, the search assumes that the aperture
at
 is no larger than that at
.  This results in tracking of
fewer particles but may give a pessimistic result.
verbosity -- A larger value results in more printouts during computations.
Michael Borland
2001-10-24
