| Parameter Name | Units | Type | Default | Description |
| L | double | 0.0 | length | |
| DX | double | 0.0 | misalignment | |
| DY | double | 0.0 | misalignment | |
| ETILT | double | 0.0 | misalignment | |
| EYAW | double | 0.0 | misalignment | |
| EPITCH | double | 0.0 | misalignment | |
| N_STEPS | long | 100 | number of steps (for nonadaptive integration) | |
| INPUTFILE | STRING | NULL | SDDS file containing (Br, Bz) vs (r, z). Each page should have values for a fixed r. | |
| RCOLUMN | STRING | NULL | column containing r values | |
| ZCOLUMN | STRING | NULL | column containing z values | |
| BRCOLUMN | STRING | NULL | column containing Br values | |
| BZCOLUMN | STRING | NULL | column containing Bz values | |
| FACTOR | double | 0.0001 | factor by which to multiply fields in file | |
| BXUNIFORM | double | 0.0 | uniform horizontal field to superimpose on solenoid field | |
| BYUNIFORM | double | 0.0 | uniform vertical field to superimpose on solenoid field | |
| LUNIFORM | double | 0.0 | length of uniform field superimposed on solenoid field | |
| ACCURACY | double | 0.0001 | integration accuracy | |
| METHOD | STRING | runge-kutta | integration method (runge-kutta, bulirsch-stoer, non-adaptive runge-kutta, modified midpoint) |
