next up previous
Next: RFDF Up: Element Dictionary Previous: RFCA
RFCW
A combination of RFCA, WAKE, and TRWAKE.
Parameter Name Units Type Default Description
L $M$ double 0.0 length
CELL_LENGTH $M$ double 0.0 cell length (used to scale wakes)
VOLT $V$ double 0.0 voltage
PHASE $DEG$ double 0.0 phase
FREQ $Hz$ double 500000000 frequency
Q   double 0.0 cavity Q
PHASE_REFERENCE   long 0 phase reference number (to link with other time-dependent elements)
CHANGE_P0   long 0 does element change central momentum?
CHANGE_T   long 0 not recommended
FIDUCIAL   STRING NULL mode for determining fiducial arrival time (light, tmean, first, pmaximum)
END1_FOCUS   long 0 include focusing at entrance?
END2_FOCUS   long 0 include focusing at exit?
BODY_FOCUS_MODEL   STRING NULL None (default) or SRS (simplified Rosenzweig/Serafini for standing wave)
N_KICKS   long 1 number of kicks to use. Set to zero for matrix method.
WAKEFILE   STRING NULL name of file containing Green functions
ZWAKEFILE   STRING NULL if WAKEFILE=NULL, optional name of file containing longitudinal Green function
TRWAKEFILE   STRING NULL if WAKEFILE=NULL, optional name of file containing transverse Green functions
TCOLUMN   STRING NULL column containing time data
WXCOLUMN   STRING NULL column containing x Green function
WYCOLUMN   STRING NULL column containing y Green function
WZCOLUMN   STRING NULL column containing longitudinal Green function
N_BINS   long 0 number of bins for current histogram
INTERPOLATE   long 0 interpolate wake?
SMOOTHING   long 0 smooth current histogram?
SG_HALFWIDTH   long 4 Savitzky-Golay filter half-width for smoothing
SG_ORDER   long 1 Savitzky-Golay filter order for smoothing
DX $M$ double 0.0 misalignment
DY $M$ double 0.0 misalignment
next up previous
Michael Borland 2001-10-24
