next up previous
Next: Namelist Command Dictionary Up: User's Manual for elegant Previous: Capabilities of elegant
Fiducialization in elegant
In some tracking codes, there is a ``fiducial particle'' that is assumed to travel along the ideal trajectory or orbit, with the ideal momentum, and at the ideal phase. There is no fiducial particle in elegant. Instead, elements are fiducialized in elegant. Fiducializing an element means determining the momentum and arrival time (or phase) of the reference particle. This is particularly important in simulations of linacs.
If the reference momentum does not change and no time-dependent elements are involved, then fiducialization is irrelevant. All elements are fiducialized at the central momentum defined in run_setup.
A number of commands have parameters for controlling fiducialization:
next up previous
Michael Borland 2002-09-02
