next up previous
Next: RFDF Up: Element Dictionary Previous: RFCA
RFCW
A combination of RFCA, WAKE, and TRWAKE.
Parameter Name Units Type Default Description
L $M$ double 0.0 length
CELL_LENGTH $M$ double 0.0 cell length (used to scale wakes)
VOLT $V$ double 0.0 voltage
PHASE $DEG$ double 0.0 phase
FREQ $Hz$ double 500000000 frequency
Q   double 0.0 cavity Q
PHASE_REFERENCE   long 0 phase reference number (to link with other time-dependent elements)
CHANGE_P0   long 0 does element change central momentum?
CHANGE_T   long 0 not recommended
FIDUCIAL   STRING NULL mode for determining fiducial arrival time (light, tmean, first, pmaximum)
END1_FOCUS   long 0 include focusing at entrance?
END2_FOCUS   long 0 include focusing at exit?
BODY_FOCUS_MODEL   STRING NULL None (default) or SRS (simplified Rosenzweig/Serafini for standing wave)
N_KICKS   long 1 number of kicks to use. Set to zero for matrix method.
WAKEFILE   STRING NULL name of file containing Green functions
ZWAKEFILE   STRING NULL if WAKEFILE=NULL, optional name of file containing longitudinal Green function
TRWAKEFILE   STRING NULL if WAKEFILE=NULL, optional name of file containing transverse Green functions
TCOLUMN   STRING NULL column containing time data
WXCOLUMN   STRING NULL column containing x Green function
WYCOLUMN   STRING NULL column containing y Green function
WZCOLUMN   STRING NULL column containing longitudinal Green function
N_BINS   long 0 number of bins for current histogram
INTERPOLATE   long 0 interpolate wake?
SMOOTHING   long 0 smooth current histogram?
SG_HALFWIDTH   long 4 Savitzky-Golay filter half-width for smoothing
SG_ORDER   long 1 Savitzky-Golay filter order for smoothing
DX $M$ double 0.0 misalignment
DY $M$ double 0.0 misalignment
LINEARIZE   long 0 Linearize phase dependence?
This element is a combination of the RFCA, WAKE, and TRWAKE elements. As such, it provides combined simulation of an rf cavity with longitudinal and transverse wakes.
For the wakes, the input files and their interpretation are identical to WAKE and TRWAKE, except that the transverse and longitudinal wakes are interpreted as the wakes for a single cell of length given by the CELL_LENGTH parameter.
Users should read the entries for WAKE, TRWAKE, and RFCA for more details on this element.
next up previous
Michael Borland 2002-09-02
