Next: amplification_factors
Up: Namelist Command Dictionary
Previous: Namelist Command Dictionary
- type: action command.
- function: modify the value of a parameter for one or more elements
&alter_elements
STRING name = NULL;
STRING item = NULL;
STRING type = NULL;
STRING exclude = NULL;
double value = 0;
STRING string_value = NULL;
long differential = 0;
long multiplicative = 0;
long verbose = 0;
long allow_missing_parameters = 0;
&end
name -- A possibly-wildcard-containing string giving the names of the
elements to alter. If not specified, then one must specify type.
item -- The name of the parameter to alter.
type -- A possibly-wildcard-containing string giving the names of element
types to alter. May be specified with name or by itself.
exclude -- A possibly-wildcard-containing string giving the names of elements
to excluded from alteration.
value, string_value -- The new value for the parameter. Use
string_value only if the parameter takes a character string as its value.
differential -- If nonzero, the new value is
the predefined value of the parameter plus the quantity given with value.
multiplicative -- If nonozero, the new given value is the predefined
value of the parameter times the quantity given with value.
verbose -- If nonzero, information is printed to the standard output describing
what elements are changed.
allow_missing_parameters -- If nonzero, then it is not an error if an
element does not have the parameter named with item. Normally, such
an occurence is an error and terminates the program.
Michael Borland
2002-09-02
