next up previous
Next: TUBEND Up: Element Dictionary Previous: TRFMODE
TRWAKE
Transverse wake specified as a function of time lag behind the particle.
Parameter Name Units Type Default Description
INPUTFILE   STRING NULL name of file giving Green functions
TCOLUMN   STRING NULL column in INPUTFILE containing time data
WXCOLUMN   STRING NULL column in INPUTFILE containing x Green function
WYCOLUMN   STRING NULL column in INPUTFILE containing y Green function
CHARGE $C$ double 0.0 beam charge (or use CHARGE element)
FACTOR $C$ double 1 factor to multiply wake by
N_BINS   long 128 number of bins for current histogram
INTERPOLATE   long 0 interpolate wake?
SMOOTHING   long 0 smooth current histogram?
SG_HALFWIDTH   long 4 Savitzky-Golay filter half-width for smoothing
SG_ORDER   long 1 Savitzky-Golay filter order for smoothing
DX $M$ double 0.0 misalignment
DY $M$ double 0.0 misalignmnet
The input file for this element gives the transverse-wake Green functions, $W_x(t)$ and $W_y(t)$, versus time behind the particle. The units of the wakes are V/C/m, so this element simulates the integrated wake of some structure (e.g., a cell or series of cells). If you have, for example, the wake for a cell and you need the wake for N cells, then you may use the FACTOR parameter to make the appropriate multiplication. The values of the time coordinate should begin at 0 and be equi-spaced. A positive value of time represents the distance behind the exciting particle.
Use of the CHARGE parameter on the TRWAKE element is disparaged. It is preferred to use the CHARGE element as part of your beamline to define the charge.
Setting the N_BINS paramater to 0 is recommended. This results in auto-scaling of the number of bins to accomodate the beam. The bin size is fixed by the spacing of the time points in the wake.
The default degree of smoothing (SG_HALFWIDTH=4) may be excessive. It is suggested that users vary this parameter to verify that results are reliable if smoothing is employed (SMOOTHING=1).
next up previous
Michael Borland 2002-09-02
