Next: error_control
Up: Namelist Command Dictionary
Previous: divide_elements
- type: setup command.
- function: assert a random error defintion for the accelerator.
&error_element
STRING name = NULL;
STRING element_type = NULL;
STRING item = NULL;
STRING type = "gaussian";
double amplitude = 0.0;
double cutoff = 3.0;
long bind = 1;
long bind_number = 0;
long post_correction = 0;
long fractional = 0;
long additive = 1;
STRING after = NULL;
STRING before = NULL;
&end
name -- The possibly wildcarded name of the elements for which errors are being specified.
element_type -- An optional, possibly wildcarded string giving the type of elements to
which the errors should be applied. E.g., element_type=*MON* would match all beam position monitors.
If this item is given, then name may be left blank.
item -- The parameter of the elements to which the error pertains.
type -- The type of random distribution to use. May be one of ``uniform'', ``gaussian'', or ``plus_or_minus''.
A ``plus_or_minus'' error is equal in magnitude to the amplitude given, with the sign randomly chosen.
amplitude -- The amplitude of the errors.
cutoff -- The cutoff for the random distribution.
bind, bind_number -- If bind_number is positive, then a positive value of bind
indicates that bind_number successive elements having the same name will have the same error value. If
bind is negative, then the sign of the error is alternated between successive elements.
post_correction -- A flag indicating whether the errors should be added after orbit, tune, and chromaticity correction.
fractional -- A flag indicating whether the errors are fractional, in which case the amplitude refers to
the amplitude of the fractional error.
additive -- A flag indicating that the errors should be added to the prior value of the
parameter. If zero, then the errors replace the prior value of the parameter.
after -- The name of an element. If given, the error is applied only to elements
that follow the named element in the beamline.
before -- The name of an element. If given, the error is applied only to elements
that precede the named element in the beamline.
Next: error_control
Michael Borland
2002-09-02
