Next: track
Up: Namelist Command Dictionary
Previous: twiss_analysis
- type: action/setup command.
- function: compute and output Twiss parameters, or set up to do so.
&twiss_output
STRING filename = NULL;
long matched = 1;
long output_at_each_step = 0;
long output_before_tune_correction = 0;
long final_values_only = 0;
long statistics = 0;
long radiation_integrals = 0;
long concat_order = 3;
double beta_x = 1;
double alpha_x = 0;
double eta_x = 0;
double etap_x = 0;
double beta_y = 1;
double alpha_y = 0;
double eta_y = 0;
double etap_y = 0;
STRING reference_file = NULL;
STRING reference_element = NULL;
long reference_element_occurrence = 0;
&end
filename -- The (incomplete) name of an SDDS file to which the Twiss parameters will be written.
Recommended value: ``%s.twi''.
matched -- A flag indicating, if set, that the periodic or matched Twiss parameters should be found.
output_at_each_step -- A flag indicating, if set, that output is desired at each step of the simulation.
output_before_tune_correction -- A flag indicating, if set, that output is desired both before and after
tune correction.
final_values_only -- A flag indicating, if set, that only the final values of the Twiss parameters should
be output, and not the parameters as a function of s.
statistics -- A flag indicating, if set, that minimum, maximum, and average values of
Twiss parameters should be computed and included in output.
radiation_integrals -- A flag indicating, if set, that radiation integrals should be computed
beta_X, alpha_X, eta_X, etap_X -- If matched is zero, the initial values for
the X plane.
concat_order -- Order of matrix concatenation to use for determining matrix for
computation of Twiss parameters. Using a lower order will result in inaccuracy for nonlinear
lattices with orbits. However, if the orbit is zero, it is much faster to use
concat_order=1.
reference_file -- If given, the name of a file from which twiss parameter data will
be taken to give the starting values. Ignored if matched is nonzero. The file
should have the beta and alpha functions with the same names as the file created by
this command.
reference_element -- Element in reference_file at which to take the
twiss parameter values. If not given, the values at the last element in reference_file
are used.
reference_element_occurrence -- Ignored if reference_element is not given.
Otherwise, the occurence number of reference_element to use. If 0, the last
occurence is used.
Next: track
Michael Borland
2002-09-02
