Next: vary_element
Up: Namelist Command Dictionary
Previous: track
- type: setup command.
- function: prepare for computation of tune shifts with amplitude.
- note: must be given prior to the
twiss_output command.
- method: tune shifts with amplitude are computed via tracking a series of
particles at different amplitudes. NAFF is used to determine the tunes
from the tracking data. It is the user's responsbility to optimize the
parameters to ensure that results are reasonable. Using tracking to determine
tune shifts is more accurate than analytical methods as it includes multi-turn
effects that are important in some rings (e.g., the APS).
&tune_shift_with_amplitude
long turns = 1000;
double x0 = 1e-10;
double y0 = 1e-10;
double x1 = 1e-6;
double y1 = 1e-6;
long use_concatenation = 1;
&end
turns -- The number of turns to track. If zero, then the concatenated matrix
is used instead of tracking. This doesn't work well with all lattices. The order
of the concatenated matrix is given by the concat_order control in
twiss_output.
x0, y0 -- The initial x and y amplitudes to use for determining the
small-amplitude tunes.
x1, y1 -- The initial x and y amplitudes to user for determining the
tune shifts. These values should be small enough to ensure linearity in the tune
shift. If the difference in tune is greater than 0.01, elegant will automatically
reduce these initial values and iterate.
use_concatenation -- If nonzero, then tracks with the concatenated matrix instead
of element-by-element. The order
twiss_output. The user should experiment with this option to see if the
results are reliable for a particular lattice.
Next: vary_element
Previous: track
Michael Borland
2002-09-02
