next up previous
Next: NISEPT Up: Element Dictionary Previous: MULT
NIBEND
A numerically-integrated dipole magnet with various extended-fringe-field models.
Parameter Name Units Type Default Description
L $M$ double 0.0 arc length
ANGLE $RAD$ double 0.0 bending angle
E1 $RAD$ double 0.0 entrance edge angle
E2 $RAD$ double 0.0 exit edge angle
TILT   double 0.0 rotation about incoming longitudinal axis
DX $M$ double 0.0 misalignment
DY $M$ double 0.0 misalignment
DZ $M$ double 0.0 misalignment
FINT   double 0.5 edge-field integral
HGAP $M$ double 0.0 half-gap between poles
FP1 $M$ double 10 fringe parameter (tanh model)
FP2 $M$ double 0.0 not used
FP3 $M$ double 0.0 not used
FP4 $M$ double 0.0 not used
FSE   double 0.0 fractional strength error
ETILT   double 0.0 error rotation about incoming longitudinal axis
ACCURACY   double 0.0001 integration accuracy (for nonadaptive integration, used as the step-size)
MODEL   STRING linear fringe model (hard-edge, linear, cubic-spline, tanh, quintic, enge1, enge3, enge5)
METHOD   STRING runge-kutta integration method (runge-kutta, bulirsch-stoer, modified-midpoint, two-pass modified-midpoint, leap-frog, non-adaptive runge-kutta)
SYNCH_RAD   long 0 include classical synchrotron radiation?
ADJUST_BOUNDARY   long 1 adjust fringe boundary position to make symmetric trajectory? (Not done if ADJUST_FIELD is nonzero.)
ADJUST_FIELD   long 0 adjust central field strength to make symmetric trajectory?
next up previous
Robert Soliday 2003-10-17
