&twiss_output
STRING filename = NULL;
long matched = 1;
long output_at_each_step = 0;
long output_before_tune_correction = 0;
long final_values_only = 0;
long statistics = 0;
long radiation_integrals = 0;
long concat_order = 3;
long higher_order_chromaticity = 0;
double beta_x = 1;
double alpha_x = 0;
double eta_x = 0;
double etap_x = 0;
double beta_y = 1;
double alpha_y = 0;
double eta_y = 0;
double etap_y = 0;
STRING reference_file = NULL;
STRING reference_element = NULL;
long reference_element_occurrence = 0;
&end
filename -- The (incomplete) name of an SDDS file to which the Twiss parameters will be written.
Recommended value: ``%s.twi''.
matched -- A flag indicating, if set, that the periodic or matched Twiss parameters should be found.
output_at_each_step -- A flag indicating, if set, that output is desired at each step of the simulation.
output_before_tune_correction -- A flag indicating, if set, that output is desired both before and after
tune correction.
final_values_only -- A flag indicating, if set, that only the final values of the Twiss parameters should
be output, and not the parameters as a function of s.
statistics -- A flag indicating, if set, that minimum, maximum, and average values of
Twiss parameters should be computed and included in output.
radiation_integrals -- A flag indicating, if set, that radiation integrals should be computed
and included in output. N.B.: Radiation integral computation is not correct for systems with vertical
bending, nor does it take into account coupling.
beta_X, alpha_X, eta_X, etap_X -- If matched is zero, the initial values for
the X plane.
concat_order -- Order of matrix concatenation to use for
determining matrix for computation of Twiss parameters. Using a lower
order will result in inaccuracy for nonlinear lattices with orbits
and/or momentum errors. However, for on-momentum conditions with zero
orbit, it is much faster to use concat_order=1.
higher_order_chromaticity -- If nonzero, requests
computation of the second- and third-order chromaticity. To obtain
reliable values, the user should use concat_order=3 in this
namelist and the highest available order for all beamline elements.
reference_file -- If given, the name of a file from which twiss parameter data will
be taken to give the starting values. Ignored if matched is nonzero. The file
should have the beta and alpha functions with the same names as the file created by
this command.
reference_element -- Element in reference_file at which to take the
twiss parameter values. If not given, the values at the last element in reference_file
are used.
reference_element_occurrence -- Ignored if reference_element is not given.
Otherwise, the occurence number of reference_element to use. If 0, the last
occurence is used.
The output file from this command contains the following columns, giving values of quantities at the exit of each element, unless otherwise noted.
The output file contains the following parameters. Note that chromatic quantities depend on the order
settings of the individual elements, the default order (in run_setup), and the concatenation order
given in the twiss_output command. These quantities pertain to the end of the lattice or to the
lattice as a whole.
higher_order_chromaticity is zero.
tune_shift_with_amplitude command is given.
N.B.: the higher-order dispersion and higher-order chromaticity are computed using the concatenated third-order matrix. However, elegant only has third-order matrices for three elements: alpha magnets, quadrupoles, and sextupoles. This may be acceptable if any dipoles (for example) have large bending radius. Users who are concerned about these effects should perform off-energy tracking using canonical elements (i.e., CSBEND, KQUAD, KSEXT, and MULT), which include energy dependence to all orders.
Also, note that by default all elements are computed to second order
only. You must change the default\_order parameter on
run\_setup to 3 in order to use the third-order matrices
for alpha magnets, quadrupoles, and sextupoles. You may also use the
ORDER parameter on individual element definitions.
