next up previous
Next: KSBEND Up: Element Dictionary Previous: KPOLY
KQUAD
A canonical kick quadrupole, which differs from the MULT element with ORDER=1 in that it can be used for tune correction.
Parameter Name Units Type Default Description
L $M$ double 0.0 length
K1 $1/M^{2}$ double 0.0 geometric strength
TILT $RAD$ double 0.0 rotation about longitudinal axis
BORE $M$ double 0.0 bore radius
B $T$ double 0.0 pole tip field (used if bore nonzero)
DX $M$ double 0.0 misalignment
DY $M$ double 0.0 misalignment
DZ $M$ double 0.0 misalignment
FSE $M$ double 0.0 fractional strength error
HKICK $RAD$ double 0.0 horizontal correction kick
VKICK $RAD$ double 0.0 vertical correction kick
HSTEERING   long 0 use for horizontal correction?
VSTEERING   long 0 use for vertical correction?
N_KICKS   long 4 number of kicks
SYNCH_RAD   long 0 include classical synchrotron radiation?
SYSTEMATIC_MULTIPOLES   STRING NULL input file for systematic multipoles
RANDOM_MULTIPOLES   STRING NULL input file for random multipoles
STEERING_MULTIPOLES   STRING NULL input file for multipole content of steering kicks
INTEGRATION_ORDER   long 4 integration order (2 or 4)
This element simulates a quadrupole using a kick method based on symplectic integration. The user specifies the number of kicks and the order of the integration. For computation of twiss parameters and response matrices, this element is treated like a standard thick-lens quadrupole; i.e., the number of kicks and the integration order become irrelevant.
Specification of systematic and random multipole errors is supported through the SYSTEMATIC_MULTIPOLES and RANDOM_MULTIPOLES fields. These fields give the names of SDDS files that supply the multipole data. The files are expected to contain a single page of data with the following elements:
  1. Floating point parameter referenceRadius giving the reference radius for the multipole data.
  2. An integer column named order giving the order of the multipole. The order is defined as $(N_{poles}-2)/2$, so a quadrupole has order 1, a sextupole has order 2, and so on.
  3. Floating point columns an and bn giving the values for the normal and skew multipole strengths, respectively. These are defined as a fraction of the main field strength measured at the reference radius, R: $a_n = \frac{K_n r^n / n!}{K_m r^m / m!}$, where $m=1$ is the order of the main field and $n$ is the order of the error multipole. A similar relationship holds for the skew multipoles. For random multipoles, the values are interpreted as rms values for the distribution.
Specification of systematic higher multipoles due to steering fields is supported through the STEERING_MULTIPOLES field. This field gives the name of an SDDS file that supplies the multipole data. The file is expected to contain a single page of data with the following elements:
  2. An integer column named order giving the order of the multipole. The order is defined as $(N_{poles}-2)/2$. The order must be an even number because of the quadrupole symmetry.
  3. Floating point column an giving the values for the normal multipole strengths, which are driven by the horizontal steering field. an is specifies the multipole strength as a fraction of the steering field strength measured at the reference radius, R: $a_n = \frac{K_n r^n / n!}{K_m r^m / m!}$, where $m=0$ is the order of the steering field and $n$ is the order of the error multipole. The bn values are deduced from the an values, specifically, $b_n = a_n*(-1)^{n/2}$.
The dominant systematic multipole term in the steering field is a sextupole. Note that elegant presently does not include such sextupole contributions in the computation of the chromaticity via the twiss_output command. However, these chromatic effects will be seen in tracking.
next up previous
Robert Soliday 2003-10-17
