Parameter Name | Units | Type | Default | Description |
L | ![]() |
double | 0.0 | length |
DX | ![]() |
double | 0.0 | misalignment |
DY | ![]() |
ETILT | ![]() |
EYAW | ![]() |
EPITCH | ![]() |
N_STEPS | long | 100 | number of steps (for nonadaptive integration) | |
INPUTFILE | STRING | NULL | SDDS file containing (Br, Bz) vs (r, z). Each page should have values for a fixed r. | |
RCOLUMN | STRING | NULL | column containing r values | |
ZCOLUMN | STRING | NULL | column containing z values | |
BRCOLUMN | STRING | NULL | column containing Br values | |
BZCOLUMN | STRING | NULL | column containing Bz values | |
FACTOR | double | 0.0001 | factor by which to multiply fields in file | |
BXUNIFORM | double | 0.0 | uniform horizontal field to superimpose on solenoid field | |
BYUNIFORM | double | 0.0 | uniform vertical field to superimpose on solenoid field | |
LUNIFORM | double | 0.0 | length of uniform field superimposed on solenoid field | |
ACCURACY | double | 0.0001 | integration accuracy | |
METHOD | STRING | runge-kutta | integration method (runge-kutta, bulirsch-stoer, non-adaptive runge-kutta, modified midpoint) |
