Parameter Name | Units | Type | Default | Description |
L | ![]() |
double | 0.0 | arc length |
ANGLE | ![]() |
double | 0.0 | bending angle |
E1 | ![]() |
double | 0.0 | entrance edge angle |
E2 | ![]() |
double | 0.0 | exit edge angle |
TILT | double | 0.0 | rotation about incoming longitudinal axis | |
DX | ![]() |
double | 0.0 | misalignment |
DY | ![]() |
DZ | ![]() |
FINT | double | 0.5 | edge-field integral | |
HGAP | ![]() |
double | 0.0 | half-gap between poles |
FP1 | ![]() |
double | 10 | fringe parameter (tanh model) |
FP2 | ![]() |
double | 0.0 | not used |
FP3 | ![]() |
FP4 | ![]() |
FSE | double | 0.0 | fractional strength error | |
ETILT | double | 0.0 | error rotation about incoming longitudinal axis | |
ACCURACY | double | 0.0001 | integration accuracy (for nonadaptive integration, used as the step-size) | |
MODEL | STRING | linear | fringe model (hard-edge, linear, cubic-spline, tanh, quintic, enge1, enge3, enge5) | |
METHOD | STRING | runge-kutta | integration method (runge-kutta, bulirsch-stoer, modified-midpoint, two-pass modified-midpoint, leap-frog, non-adaptive runge-kutta) | |
SYNCH_RAD | long | 0 |
include classical synchrotron radiation? | |
ADJUST_BOUNDARY | long | 1 | adjust fringe boundary position to make symmetric trajectory? (Not done if ADJUST_FIELD is nonzero.) |
A numerically-integrated dipole magnet with various extended-fringe-field models.
ADJUST_FIELD | long | 0 |
adjust central field strength to make symmetric trajectory? |
