Parameter Name | Units | Type | Default | Description |
RA | ![]() |
double | 0.0 | shunt impedance |
RS | ![]() |
double | 0.0 | shunt impedance (Ra=2*Rs) |
Q | double | 0.0 | cavity Q | |
FREQ | ![]() |
double | 0.0 | frequency |
CHARGE | ![]() |
double | 0.0 | beam charge (or use CHARGE element) |
INITIAL_V | ![]() |
double | 0.0 | initial voltage |
INITIAL_PHASE | ![]() |
double | 0.0 | initial phase |
INITIAL_T | ![]() |
double | 0.0 | time at which INITIAL_V and INITIAL_PHASE held |
BETA | double | 0.0 | normalized load impedance | |
BIN_SIZE | ![]() |
double | 0.0 | bin size for current histogram (use 0 for autosize) |
N_BINS | long | 20 | number of bins for current histogram | |
PRELOAD | long | 0 |
preload cavity with steady-state field | |
PRELOAD_FACTOR | double | 1 | multiply preloaded field by this value | |
RIGID_UNTIL_PASS | long | 0 |
don't affect the beam until this pass | |
DETUNED_UNTIL_PASS | long | 0 |
cavity is completely detuned until this pass | |
SAMPLE_INTERVAL | long | 1 | passes between output to RECORD file | |
RECORD | STRING | NULL | output file for cavity fields | |
SINGLE_PASS | long | 0 |
if nonzero, don't accumulate field from pass to pass | |
PASS_INTERVAL | long | 1 | interval in passes at which to apply PASS_INTERVAL times the field (may increase speed) | |
FREQ_WAVEFORM | STRING | NULL | ![]() ![]() ![]() ![]() ![]() ![]() |
A simulation of a beam-driven TM monopole mode of an RF cavity.
