| Parameter Name | Units | Type | Default | Description |
| L | double | 0.0 | Length to be used for matrix-based operations such as twiss parameter computation. | |
| COMMAND | STRING | NULL | SDDS-compliant command to apply to the beam. Use the sequence %i to represent the input filename and %o to represent the output filename. | |
| USE_CSH | long | 1 | Use C-shell for execution (may be slower)? | |
| VERBOSITY | long | 0 |
Set the verbosity level. | |
| ROOTNAME | STRING | NULL | Rootname for use in naming input and output files. %s may be used to represent the run rootname. | |
| INPUT_EXTENSION | STRING | in | Extension for the script input file. | |
| OUTPUT_EXTENSION | STRING | out | Extension for the script output file. | |
| KEEP_FILES | long | 0 |
If nonzero, then script input and output files are not deleted after use. By default, they are deleted. | |
| NP0 | double | 0.0 | User-defined numerical parameter for command substitution for sequence %np0 | |
| NP1 | double | 0.0 | User-defined numerical parameter for command substitution for sequence %np1 | |
| NP2 | double | 0.0 | User-defined numerical parameter for command substitution for sequence %np2 | |
| NP3 | double | 0.0 | User-defined numerical parameter for command substitution for sequence %np3 | |
| NP4 | double | 0.0 | User-defined numerical parameter for command substitution for sequence %np4 |
An element that allows transforming the beam using an external script.
| NP5 | double | 0.0 | User-defined numerical parameter for command substitution for sequence %np5 | |
| NP6 | double | 0.0 | User-defined numerical parameter for command substitution for sequence %np6 | |
| NP7 | double | 0.0 | User-defined numerical parameter for command substitution for sequence %np7 | |
| NP8 | double | 0.0 | User-defined numerical parameter for command substitution for sequence %np8 | |
| NP9 | double | 0.0 | User-defined numerical parameter for command substitution for sequence %np9 | |
| SP0 | STRING | NULL | User-defined string parameter for command substitution for sequence %sp0 | |
| SP1 | STRING | NULL | User-defined string parameter for command substitution for sequence %sp1 | |
| SP2 | STRING | NULL | User-defined string parameter for command substitution for sequence %sp2 | |
| SP3 | STRING | NULL | User-defined string parameter for command substitution for sequence %sp3 | |
| SP4 | STRING | NULL | User-defined string parameter for command substitution for sequence %sp4 | |
| SP5 | STRING | NULL | User-defined string parameter for command substitution for sequence %sp5 | |
| SP6 | STRING | NULL | User-defined string parameter for command substitution for sequence %sp6 |
| SP7 | STRING | NULL | User-defined string parameter for command substitution for sequence %sp7 | |
| SP8 | STRING | NULL | User-defined string parameter for command substitution for sequence %sp8 | |
| SP9 | STRING | NULL | User-defined string parameter for command substitution for sequence %sp9 |
This element allows expanding elegant by using external scripts
(or programs) as elements in a beamline. Here are requirements for the
script:
The SCRIPT element works best if the script accepts commandline arguments. In this case, the COMMAND parameter is used to provide a template for creating a command to run the script. The COMMAND string may contain the following substitutable fields:
%i -- Will be replaced by the name of the input file to the script.
(elegant writes the initial particle distribution to this file.)
%o -- Will be replaced by the name of the output file from the script.
(elegant expects the script to write the final particle distribution to this file.)
%np0, %np1, ..., %np9 -- Will be replaced by the value of
Numerical Parameter 0, 1, ..., 9. This can be used to pass to the script values that
are parameters of the element definition. For example, if one wanted to vary parameters
or add errors to the parameter, one would use this facility.
%sp0, %sp1, ..., %sp9 -- Will be replaced by the value of
String Parameter 0, 1, ..., 9. This can be used to pass to the script values that
Here's an example of a SCRIPT COMMAND:
myScript -input %i -output %o -accuracy %np0 -type %sp0
myScript -input tmp391929.1 -output tmp391929.2 -accuracy 1.5e-6 -type scraper
If you have a program (e.g., a FORTRAN program) that does not accept commandline arguments, you can easily wrap it in a Tcl/Tk simple script to handle this. Alternatively, you can force elegant to use specified files for communicating with the script. This is done using the ROOTNAME, INPUT_EXTENSION, and OUTPUT_EXTENSION parameters. So if your program was crass and it expected its input (output) in files crass.in (crass.out), then you'd use
S1: script,command=''crass'',rootname=''crass'',input_extension=''in'',& output_extension=''out''
