| Parameter Name | Units | Type | Default | Description |
| INPUTFILE | STRING | NULL | name of file giving Green functions | |
| TCOLUMN | STRING | NULL | column in INPUTFILE containing time data | |
| WXCOLUMN | STRING | NULL | column in INPUTFILE containing x Green function | |
| WYCOLUMN | STRING | NULL | column in INPUTFILE containing y Green function | |
| CHARGE | double | 0.0 | beam charge (or use CHARGE element) | |
| FACTOR | double | 1 | factor by which to multiply both wakes | |
| XFACTOR | double | 1 | factor by which to multiply x wake | |
| YFACTOR | double | 1 | factor by which to multiply y wake | |
| N_BINS | long | 128 | number of bins for current histogram | |
| INTERPOLATE | long | 0 |
interpolate wake? | |
| SMOOTHING | long | 0 |
smooth current histogram? | |
| SG_HALFWIDTH | long | 4 | Savitzky-Golay filter half-width for smoothing | |
| SG_ORDER | long | 1 | Savitzky-Golay filter order for smoothing | |
| DX | double | 0.0 | misalignment | |
| DY | double | 0.0 | misalignment | |
| TILT | double | 0.0 | rotation about longitudinal axis | |
| XPOWER | long | 1 | Power of x that x kick depends on. | |
| YPOWER | long | 1 | Power of y that y kick depends on. |
The input file for this element gives the transverse-wake Green
functions,
and
, versus time behind the particle. The
units of the wakes are V/C/m, so this element simulates the integrated
wake of some structure (e.g., a cell or series of cells). If you
have, for example, the wake for a cell and you need the wake for N
cells, then you may use the FACTOR parameter to make the
appropriate multiplication. The values of the time coordinate should
begin at 0 and be equi-spaced. A positive value of time represents
the distance behind the exciting particle. Time values must be equally
spaced.
The sign convention for
being
or
) is as follows: a
particle with
will impart a positive kick (
) to a trailing particle following
seconds behind if
A physical wake function should be zero at
and also be initially
positive as
increases from 0.
Use of the CHARGE parameter on the TRWAKE element is disparaged. It is preferred to use the CHARGE element as part of your beamline to define the charge.
Setting the N_BINS paramater to 0 is recommended. This results in auto-scaling of the number of bins to accomodate the beam. The bin size is fixed by the spacing of the time points in the wake.
The default degree of smoothing (SG_HALFWIDTH=4) may be excessive. It is suggested that users vary this parameter to verify that results are reliable if smoothing is employed (SMOOTHING=1).
The XFACTOR and YFACTOR parameters can be used to adjust the strength of the wakes if the location at which you place the TRWAKE element has different beta functions than the location at which the object that causes the wake actually resides.
The XPOWER and YPOWER parameters can be used to change the dependence of the wake on the x and y coordinates, respectively, of the particles. Normally, XPOWER=1 and YPOWER=1. This is an ordinary dipole wake in a (supposedly) symmetric chamber.
If you have an asymmetric chamber, then you will have a transverse
wake kick even if the beam is centered. (Of course, you'll need a 3-D
wake code like GdfidL or MAFIA to compute this wake.) This part of
the transverse wake is described with XPOWER=0 and YPOWER=0. It will result in an orbit distortion, but conceivably
could have other effects, such as emittance dilution. If XPOWER=0 or YPOWER=0, the units for the x or y wake
(respectively) must be
. A negative value of the wake
corresponds to a kick toward negative x (or y).
