Next: floor_coordinates
Up: Namelist Command Dictionary
Previous: error_control
- type: action command.
- function: find the aperture in (x, y) space for an accelerator.
&find_aperture
STRING output = NULL;
STRING search_output = NULL;
STRING boundary = NULL;
STRING mode = "many-particle";
double xmin = -0.1;
double xmax = 0.1;
double ymin = 0.0;
double ymax = 0.1;
long nx = 21;
long ny = 11;
long n_splits = 0;
double split_fraction = 0.5;
double desired_resolution = 0.01;
long verbosity = 0;
long assume_nonincreasing = 0;
&end
output -- The (incomplete) name of an SDDS file to send output to.
Recommended value: ``%s.aper''.
search_output -- The (incomplete) name of an SDDS file for output of detailed
information on each tracked particle (single-particle mode only). Recommended value:
``%s.apso''.
boundary -- The (incomplete) name of an SDDS
file for the boundary points of the aperture search. Recommended value: ``%s.bnd''.
xmin, xmax, ymin, ymax -- Region of the aperture search.
mode -- May be ``many-particle'' or ``single-particle''. Many-particle searching is
much faster, but does not allow interval splitting to search for the aperture boundary.
nx -- Number of x values to take in initial search.
ny -- Number of y values to take in search.
n_splits -- If positive, the number of times to do interval splitting. Interval splitting
refers to searching between the original grid points in order to refine the results.
split_fraction -- If interval splitting is done, how the interval is split.
desired_resolution -- If interval splitting is done, fraction of xmax-xmin to which to resolve the aperture.
assume_nonincreasing -- If this variable is non-zero, the search assumes that the aperture
at
is no larger than that at
. This results in tracking of
fewer particles but may give a pessimistic result.
verbosity -- A larger value results in more printouts during computations.
Robert Soliday
2004-04-21
