&load_parameters
        STRING filename = NULL;
        STRING filename_list = NULL;
        STRING include_name_pattern = NULL;
        STRING exclude_name_pattern = NULL;
        STRING include_item_pattern = NULL;
        STRING exclude_item_pattern = NULL;
        STRING include_type_pattern = NULL;
        STRING exclude_type_pattern = NULL;
        long change_defined_values = 0;
        long clear_settings = 0;
        long allow_missing_elements = 0;
        long allow_missing_parameters = 0;
	long force_occurence_data = 0;
        long verbose = 0;
&end
filename -- Name (possibly containing the ``of SDDS file from which to take data.  The file
must contain some of the following columns:
Unless change_defined_values is set, successive pages of the
file are used for successive steps of the simulation.  Several elegant commands generate output that may be used (on a subsequent
run) with load_parameters; among these are the tune and
chromaticity correction commands and the run_setup command
(parameters output).
filename_list -- A list of filenames, which may be
        given in place of filename.  If used, each file
        in the list is treated as if it was separately supplied
        with an individual load_parameters command.
include_name_pattern, exclude_name_pattern --
Wildcard patterns to be used in selecting, respectively, which
elements to include and which to exclude from loading.
include_item_pattern, exclude_item_pattern --
Wildcard patterns to be used in selecting, respectively, which items
(i.e., which element parameters) to include and which to exclude from
loading.
include_type_pattern, exclude_type_pattern --
Wildcard patterns to be used in selecting, respectively, which element
types (e.g., QUAD, DRIFT) to include and which to exclude from
loading.
change_defined_values -- Changes the defined values of
the parameters.  This means that when the lattice is saved (using
save_lattice), the parameters will have the altered values.
Also, if one wants to alter the values for all steps of the simulation,
one must set this flag.
Note that the ElementOccurence data is normally ignored if
change_defined_values is nonzero.  This is because there is
only one definition of each element, even if it is used multiple times.
This behavior can be altered with the next control.
force_occurence_data -- If set, then occurence data is
used even in change_defined_values mode.
clear_settings -- If set, clear all settings and files
being used for loading parameters.
allow_missing_elements -- If set, allow elements in the
file that are not in the lattice.  In this case, the nonapplicable
data is simply ignored.
allow_missing_parameters -- If set, it is not an error
if any element in the lattice lacks a parameter that exists in the file.
verbose -- If set, provide informational printouts about
changes to parameters.
