Next: slice_analysis
 Up: Namelist Command Dictionary
 Previous: sdds_beam
- type: setup command.
- function: set up names for semaphore files, which are used to mark the
        start and end of program execution.
&semaphores
        STRING started = ``%s.started'';
        STRING done    = ``%s.done'';
&end
- started -- Gives the (incomplete) filename of a file to create when a valid
        run_setup command is given.
- done -- Gives the (incomplete) filename of a file to create when the program
        exits without error.  If the file exists, it is deleted when a valid run_setup
        command is given.
Robert Soliday
2004-04-21
