Next: New Elements
Up: Highlights of What's New
Previous: Modified Elements
- The run_setup command now optionally accepts the central momentum in MeV/c,
instead of just
- The tune_shift_with_amplitude command was improved to provide second-order
shifts as well as the tune spread for a specified range of amplitudes.
These quantities may be optimized.
- Added computation of the minimum and maximum tunes for a specified range
of momentum offsets. These values may be optimized.
- Optimization may now include the chromatic derivatives of the beta and alpha Twiss
parameters.
- The load_parameters command will now accept a list of input files and will
optionally ignore non-existent files.
- The lost-particles file (requested from run_setup), now includes the turn on
which each particle is lost.
- Made changes that allow computing closed orbit for the momentum offset
of the beam distribution and then starting the beam on that orbit.
The changes are to the closed_orbit and track_beam commands.
- Optimization terms with zero weight are now ignored, instead of generating an error.
- Added disable control for optimization variables and co-variables.
- Added disable control for transmute_elements.
Robert Soliday
2004-04-21
