- description:
sddsmatchtwiss transforms a beam of macro-particles to match to given beta
functions and dispersion.   This can be useful in taking macro-particle data from
one simulation and using it in another.  For example, a beam file from PARMELA
could be given the right beta functions for use with a specific lattice in an
elegant run, saving the trouble of rematching to join the two simulations.
Similarly, a beam from elegant could be matched into an FEL simulation.
- examples:
sddsmatchtwiss elegantBeam.out FELBeam.in -xPlane=beta=1.0,alpha=-0.2 -yPlane=beta=0.5,alpha=0.2
- synopsis:
sddsmatchtwiss [-pipe=[input][,output]] inputfile outputfile
[-xPlane=[beta=meters,alpha=value][,etaValue=meters][,etaSlope=value]]
[-yPlane=[beta=meters,alpha=value][,etaValue=meters][,etaSlope=value]]
[-nowarnings]
- files:
inputfile is an SDDS file containing one or more pages of data
giving the phase-space coordinates of macro particles.  The macro
particle data is stored in columns named x, xp,
y, yp, and p.  The units are those used by elegant for the output file from run_setup, the bunch file from bunched_beam, and the coordinate-mode output
from the WATCH element. The data from these columns is used
together with the commandline arguments to produce new values for
these columns; the new values are delivered to outputfile.
Other columns may be present in inputfile; if so, they are
passed to outputfile unchanged.
- switches:
- -xPlane=[beta=meters,alpha=value][,etaValue=meters][,etaSlope=value] --
        Specifies the desired parameters for the beam in the horizontal plane.  beta and alpha give
 and
; they must both be given
        or both be omitted.  etaValue and etaSlope give the dispersion,
, and
        its slope,
- -yPlane=[beta=meters,alpha=value][,etaValue=meters][,etaSlope=value] --
        Same as -xPlane, except for the vertical plane.
- -nowarnings -- Suppresses warning messages.
- author: M. Borland, ANL/APS.
