Parameter Name | Units | Type | Default | Description |
L | ![]() |
double | 0.0 | arc length |
ANGLE | ![]() |
double | 0.0 | bend angle |
K1 | ![]() |
double | 0.0 | geometric quadrupole strength |
K2 | ![]() |
double | 0.0 | geometric sextupole strength |
K3 | ![]() |
double | 0.0 | geometric octupole strength |
K4 | ![]() |
double | 0.0 | geometric decapole strength |
E1 | ![]() |
double | 0.0 | entrance edge angle |
E2 | ![]() |
double | 0.0 | exit edge angle |
TILT | ![]() |
double | 0.0 | rotation about incoming longitudinal axis |
H1 | ![]() |
double | 0.0 | entrance pole-face curvature |
H2 | ![]() |
double | 0.0 | exit pole-face curvature |
HGAP | ![]() |
double | 0.0 | half-gap between poles |
FINT | double | 0.5 | edge-field integral | |
DX | ![]() |
double | 0.0 | misalignment |
DY | ![]() |
DZ | ![]() |
FSE | double | 0.0 | fractional strength error | |
ETILT | double | 0.0 | error rotation about incoming longitudinal axis | |
N_KICKS | long | 4 | number of kicks | |
NONLINEAR | long | 1 | include nonlinear field components? | |
LINEARIZE | long | 0 |
use linear matrix instead of symplectic integrator? | |
SYNCH_RAD | long | 0 |
include classical synchrotron radiation? | |
EDGE1_EFFECTS | long | 1 | include entrace edge effects? | |
EDGE2_EFFECTS | long | 1 | include exit edge effects? | |
EDGE_ORDER | long | 1 | order to which to include edge effects | |
INTEGRATION_ORDER | long | 2 | integration order (2 or 4) |
Like CSBEND, but incorporates a simulation of Coherent Synchrotron radiation.
BINS | long | 0 |
number of bins for CSR wake | |
BIN_ONCE | long | 0 |
bin only at the start of the dipole? | |
BIN_RANGE_FACTOR | double | 1.2 | Factor by which to increase the range of histogram compared to total bunch length. Large value eliminates binning problems in CSRDRIFTs. | |
SG_HALFWIDTH | long | 0 |
Savitzky-Golay filter half-width for smoothing current histogram | |
SG_ORDER | long | 1 | Savitzky-Golay filter order for smoothing current histogram | |
SGDERIV_HALFWIDTH | long | 0 |
Savitzky-Golay filter half-width for taking derivative of current histogram | |
SGDERIV_ORDER | long | 1 | Savitzky-Golay filter order for taking derivative of current histogram | |
TRAPAZOID_INTEGRATION | long | 1 | Select whether to use trapazoid-rule integration (default) or a simple sum. | |
OUTPUT_FILE | STRING | NULL | output file for CSR wakes | |
OUTPUT_INTERVAL | long | 1 | interval (in kicks) of output to OUTPUT_FILE | |
OUTPUT_LAST_WAKE_ONLY | long | 0 |
output final wake only? | |
STEADY_STATE | long | 0 |
use steady-state wake equations? | |
USE_BN | long | 0 |
use b![]() ![]() ![]() ![]() |
B1 | ![]() |
double | 0.0 | K1 = b1*rho, where rho is bend radius |
B2 | ![]() |
double | 0.0 | b2 = B2*rho |
B3 | ![]() |
double | 0.0 | b3 = B3*rho |
B4 | ![]() |
double | 0.0 | b4 = B4*rho |
ISR | long | 0 |
include incoherent synchrotron radiation (scattering)? |
CSR | long | 1 | enable CSR computations? | |
BLOCK_CSR | long | 0 |
block CSR from entering CSRDRIFT? | |
DERBENEV_CRITERION_MODE | STRING | disable | disable, evaluate, or enforce | |
PARTICLE_OUTPUT_FILE | STRING | NULL | name of file for phase-space output | |
PARTICLE_OUTPUT_INTERVAL | long | 0 |
interval (in kicks) of output to PARTICLE_OUTPUT_FILE | |
SLICE_ANALYSIS_INTERVAL | long | 0 |
interval (in kicks) of output to slice analysis file (from slice_analysis command) | |
HIGH_FREQUENCY_CUTOFF0 | double | -1 | Spatial frequency at which smoothing filter begins. If not positive, no frequency filter smoothing is done. Frequency is in units of Nyquist (0.5/binsize). | |
HIGH_FREQUENCY_CUTOFF1 | double | -1 | Spatial frequency at which smoothing filter is 0. If not given, defaults to HIGH_FREQUENCY_CUTOFF0. | |
WAKE_FILTER_FILE | STRING | NULL | Name of file supplying wakefield filtering data. | |
WFF_FREQ_COLUMN | STRING | NULL | Name of column supplying frequency values for wakefield filtering data. | |
WFF_REAL_COLUMN | STRING | NULL | Name of column supplying real values for wakefield filtering data. | |
WFF_IMAG_COLUMN | STRING | NULL | Name of column supplying imaginary values for wakefield filtering data. |
For a discussion of the method behind this element, see M. Borland,
``Simple method for particle tracking with coherent synchrotron
radiation,'' Phys. Rev. ST Accel. Beams 4, 070701 (2001).
Recommendations for using this element. The default values for this element are not the best ones to use. They are retained only for consistency through upgrades. In using this element, it is recommended to have 50 to 100 k particle in the simulation. Setting BINS=600 and SG_HALFWIDTH=1 is also recommended to allow resolution of fine structure in the beam and to avoid excessive smoothing. It is strongly suggested that the user vary these parameters and view the histogram output to verify that the longitudinal distribution is well represented by the histograms (use OUTPUT_FILE to obtain the histograms). For LCLS simulations, we find that the above parameters give essentially the same results as obtained with 500 k particles and up to 3000 bins.
In order to verify that the 1D approximation is valid, the user should also set DERBENEV_CRITERION_MODE = ``evaluate'' and view the data in OUTPUT_FILE. Generally, the criterion should be much less than 1.
In order respects, this element is just like the CSBEND element, which provides a symplectic bending magnet that is accurate to all orders in momentum offset. The field expansion is available to fourth order.
One pitfall of symplectic integration is the possibility of orbit and path-length errors for the reference orbit if too few kicks are used. This may be an issue for rings. Hence, one must verify that a sufficient number of kicks are being used by looking at the trajectory closure and length of an on-axis particle by tracking. Using INTEGRATION_ORDER=4 is recommended to reduce the number of required kicks.
Normally, one specifies the higher-order components of the field with
the K1, K2, K3, and K4 parameters. The field
expansion in the midplane is
. By setting the USE_bN
flag to a nonzero value, one may instead specify the b1 through
b4 parameters, which are defined by the expansion
. This is convenient if one is
varying the dipole radius but wants to work in terms of constant field
quality.
Setting NONLINEAR=0 turns off all the terms above K_1 (or b_1) and also turns off effects due to curvature that would normally result in a gradient producing terms of higher order.
Edge effects are included using a first- or second-order matrix. The order is controlled using the EDGE_ORDER parameter, which has a default value of 1. N.B.: if you choose the second-order matrix, it is not symplectic.
