Parameter Name | Units | Type | Default | Description |
L | ![]() |
double | 0.0 | length |
FREQUENCY | ![]() |
double | 2856000000 | frequency |
PHASE | ![]() |
double | 0.0 | phase |
EZ_PEAK | ![]() |
double | 0.0 | Peak on-axis longitudinal electric field |
TIME_OFFSET | ![]() |
double | 0.0 | time offset (adds to phase) |
PHASE_REFERENCE | long | 0 |
phase reference number (to link to other time-dependent elements) | |
DX | ![]() |
double | 0.0 | misalignment |
DY | ![]() |
DZ | ![]() |
ETILT | ![]() |
EYAW | ![]() |
EPITCH | ![]() |
N_STEPS | long | 100 | number of steps (for nonadaptive integration) | |
RADIAL_ORDER | long | 1 | highest order in off-axis expansion | |
CHANGE_P0 | long | 0 |
does element change central momentum? | |
INPUTFILE | STRING | NULL | file containing Ez vs z at r=0 | |
ZCOLUMN | STRING | NULL | column containing z values | |
EZCOLUMN | STRING | NULL | column containing Ez values | |
SOLENOID_FILE | STRING | NULL | file containing map of Bz and Br vs z and r. Each page contains values for a single r. | |
SOLENOID_ZCOLUMN | STRING | NULL | column containing z values for solenoid map. | |
SOLENOID_RCOLUMN | STRING | NULL | column containing r values for solenoid map. If omitted, data is assumed to be for r=0 and an on-axis expansion is performed. |
A TM-mode RF cavity specified by the on-axis Ez field.
SOLENOID_BZCOLUMN | STRING | NULL | column containing Bz values for solenoid map. | |
SOLENOID_BRCOLUMN | STRING | NULL | column containing Br values for solenoid map. If omitted, data is assumed to be for r=0 and an on-axis expansion is performed. | |
SOLENOID_FACTOR | double | 1 | factor by which to multiply solenoid fields. | |
SOLENOID_DX | ![]() |
SOLENOID_DY | ![]() |
SOLENOID_DZ | ![]() |
SOLENOID_ETILT | ![]() |
SOLENOID_EYAW | ![]() |
SOLENOID_EPITCH | ![]() |
BX_STRAY | double | 0.0 | Uniform stray horizontal field | |
BY_STRAY | double | 0.0 | Uniform stray vertical field | |
ACCURACY | double | 0.0001 | integration accuracy | |
METHOD | STRING | runge-kutta | integration method (runge-kutta, bulirsch-stoer, non-adaptive runge-kutta, modified midpoint) | |
FIDUCIAL | STRING | t,median | {t![]() ![]() ![]() ![]() ![]() ![]() |
FIELD_TEST_FILE | STRING | NULL | filename for output of test fields (r=0) |
