| Parameter Name | Units | Type | Default | Description |
| ID | STRING | NULL | System identifier | |
| PLANE | STRING | x | "x" or "y" | |
| RMS_NOISE | double | 0.0 | RMS noise to add to position readings. | |
| A0 | double | 0.0 | Filter coefficient | |
| A1 | double | 0.0 | Filter coefficient | |
| A2 | double | 0.0 | Filter coefficient | |
| A3 | double | 0.0 | Filter coefficient | |
| A4 | double | 0.0 | Filter coefficient | |
| A5 | double | 0.0 | Filter coefficient | |
| A6 | double | 0.0 | Filter coefficient | |
| A7 | double | 0.0 | Filter coefficient | |
| A8 | double | 0.0 | Filter coefficient | |
| A9 | double | 0.0 | Filter coefficient | |
| A10 | double | 0.0 | Filter coefficient | |
| A11 | double | 0.0 | Filter coefficient | |
| A12 | double | 0.0 | Filter coefficient | |
| A13 | double | 0.0 | Filter coefficient | |
| A14 | double | 0.0 | Filter coefficient |
This element is used together with the TFBDRIVER element to
simulate a digital transverse feedback system.  Each TFBPICKUP
element must have a unique identification string assigned to it using
the ID parameter.  This is used to identify which drivers get
signals from the pickup.
A 15-term FIR filter can be defined using the A0 through A14 parameters.  The input to the filter is the turn-by-turn beam
centroid at the pickup location.  The output of the filter is simply
, where
 is the position from
 turns
ago.  Note that
 must be zero. Otherwise, the
system will attempt to correct the DC orbit.  The output of the filter
is the input to the driver element(s).
See Section 7.2.14 of Handbook of Accelerator Physics and Engineering (Chao and Tigner, eds.) for a discussion of feedback systems.
