Next: error_element
Up: Namelist Command Dictionary
Previous: correct_tunes
- type: setup command.
- function: define how to subdivide certain beamline elements.
- notes:
- Any number of these commands may be given.
- Not effective unless given prior to
run_setup.
- The
element_divisions
field in run_setup provides a simpler, but less flexible, method of performing
element division. At present, these element types may be divided:
QUAD, SBEN, RBEN, DRIF, SEXT.
- Only effective if given prior to the
run_setup command.
- warnings:
- Using
save_lattice and element divisions together will
produce an incorrect lattice file.
- Element subdivision may
produce unexpected results when used with
load_parameters
or parameters saved via the parameter
entry of the run_setup command.
If you wish to load parameters while doing element divisions or if
you wish to load parameters from a run that had element divisions
in effect, you should not load length data for any elements that
are (or were) split. The name and item pattern features of
load_parameters are helpful in restricting what is loaded.
÷_elements
STRING name = NULL;
STRING type = NULL;
STRING exclude = NULL;
long divisions = 0;
double maximum_length = 0;
long clear = 0;
&end
name -- A possibly wildcard-containing string specifying
the elements to which this specification applies.
type -- A possibly wildcard-containing string specifying
the element types to which this specification applies.
exclude -- A possibily wildcard-containing string specifying
elements to be excluded from the specification.
divisions -- The number of times to subdivide the specified
elements. If zero, then maximum_length should be nonzero.
maximum_length -- The maximum length of a slice. This is
usually preferrable to specifying the number of divisions, particularly
when the elements divided may be of different lengths. If zero, then
divisions should be nonzero.
clear -- If nonzero, all prior division specifications are
deleted.
Next: error_element
Louis Emery
2005-03-16
