Next: New Elements
 Up: Highlights of What's New
 Previous: Modified Elements
- Frequency map analysis now outputs tunes on range from [0, 1],
instead of [0, 0.5].  Louis Emery assisted with this improvement and
provided ideas for the algorithm.
- One can now use differential and multiplicative mode simultaneously for
alter_elements.
- Added minimumn and maximumn columns to the sigma
output file from run_setup, where n is 1 to 6.  These columns
give the minimum and maximum amplitude of the corresponding
phase-space coordinate.  Fixed problem with units for sij output.  Fixed a bug that resulted in wrong sigma values in
the output file for single-particle beam.
- The transmute_elements command can now transmute an
element that has the LENGTH parameter into an element that doesn't have
LENGTH, as long as the length is zero.
Louis Emery
2005-03-16
