Parameter Name | Units | Type | Default | Description |
L | ![]() |
double | 0.0 | length |
STRENGTH | ![]() |
double | 0.0 | factor by which to multiply field |
ACCURACY | ![]() |
double | 0.0 | integration accuracy |
METHOD | ![]() |
STRING | NULL | integration method (runge-kutta, bulirsch-stoer, modified-midpoint, two-pass modified-midpoint, leap-frog, non-adaptive runge-kutta |
FILENAME | ![]() |
STRING | NULL | name of file containing columns (x, y, Fx, Fy) giving normalized field (Fx, Fy) vs (x, y) |
This element simulates transport through a transverse magnetic field
specified as a field map. It does this by simply integrating the
Lorentz force equation in cartesian coordinates. It does not
incorporate changes in the design trajectory resulting from the
fields. I.e., if you input a dipole field, it is interpreted as a
steering element.
The field map file is an SDDS file with the following columns:
The field map file must contain a rectangular grid of points, equispaced (separately) in x and y. There should be no missing values in the grid (this is not checked by elegant). In addition, the x values must vary fastest as the values are accessed in row order. To ensure that this is the case, use the following command on the field file:
