| Parameter Name | Units | Type | Default | Description |
| L | double | 0.0 | length | |
| K2 | double | 0.0 | geometric strength | |
| TILT | double | 0.0 | rotation about longitudinal axis | |
| BORE | double | 0.0 | bore radius | |
| B | double | 0.0 | field at pole tip (used if bore nonzero) | |
| DX | double | 0.0 | misalignment | |
| DY | double | 0.0 | misalignment | |
| DZ | double | 0.0 | misalignment | |
| FSE | double | 0.0 | fractional strength error | |
| N_KICKS | long | 4 | number of kicks | |
| SYNCH_RAD | long | 0 |
include classical synchrotron radiation? | |
| SYSTEMATIC_MULTIPOLES | STRING | NULL | input file for systematic multipoles | |
| RANDOM_MULTIPOLES | STRING | NULL | input file for random multipoles | |
| INTEGRATION_ORDER | long | 4 | integration order (2 or 4) | |
| SQRT_ORDER | long | 0 |
Order of expansion of square-root in Hamiltonian. 0 means no expansion. |
This element simulates a sextupole using a kick method based on
symplectic integration. The user specifies the number of kicks and
the order of the integration. For computation of twiss parameters,
chromaticities, and response matrices, this element is treated like a
standard thick-lens sextuupole; i.e., the number of kicks and the
integration order become irrelevant.
SYSTEMATIC_MULTIPOLES and
RANDOM_MULTIPOLES
fields. These fields give the names of SDDS files that supply the
multipole data. The files are expected to contain a single page of
data with the following elements:
