Next: RFTMEZ0
Up: Element Dictionary
Previous: RFMODE
Tracks through a TM110-mode (deflecting) rf cavity with all magnetic and electric field components.
| Parameter Name |
Units |
Type |
Default |
Description |
| PHASE |
double |
0.0 |
phase |
| TILT |
double |
0.0 |
rotation about longitudinal axis |
| FREQUENCY |
double |
2856000000 |
frequency |
| VOLTAGE |
double |
0.0 |
peak deflecting voltage |
| PHASE_REFERENCE |
long |
0 |
phase reference number (to link with other time-dependent elements) |
| VOLTAGE_WAVEFORM |
STRING |
NULL |
filename = x + y form specification of input file giving voltage waveform factor vs time |
| VOLTAGE_PERIODIC |
long |
0 |
If non-zero, voltage waveform is periodic with period given by time span. |
| ALIGN_WAVEFORMS |
long |
0 |
If non-zero, waveforms' t=0 is aligned with first bunch arrival time. |
| VOLTAGE_NOISE |
double |
0.0 |
Rms fractional noise level for voltage. |
| PHASE_NOISE |
double |
0.0 |
Rms noise level for phase. |
| GROUP_VOLTAGE_NOISE |
double |
0.0 |
Rms fractional noise level for voltage linked to group. |
| GROUP_PHASE_NOISE |
double |
0.0 |
Rms noise level for phase linked to group. |
| VOLTAGE_NOISE_GROUP |
long |
0 |
Group number for voltage noise. |
| PHASE_NOISE_GROUP |
long |
0 |
Group number for phase noise. |
To derive the field expansion, we start with some results from
Jackson[16], section 8.7. The longitudinal electric field
for a TM mode is just
(12) |
where
is an integer,
is the length of the cavity, and we use
cylindrical coordinates
. The factor of
represents a
choice of sign and phase convention. We are interested in the
TM110 mode, so we set
. In this case, we have
(13) |
and (using CGS units)
(14) |
For a cylindrical cavity, the function
for the
aximuthal mode is
(15) |
where
is the first zero of
, and
is the cavity radius.
We don't need to know the cavity radius, since
, where
is the
resonant frequency. By choosing
for the aximuthal dependence, we'll get
a magnetic field primarily in the vertical direction.
In MKS units, the magnetic field is
(16) |
Using mathematica, we expanded these expressions to sixth order
in
. Here, we present only the expressions to second
order. Taking the real parts only, we now have
The Cartesian components of
can be computed easily
The Lorentz force on an electron is
giving
We see that for
, we have
, and
(27) |
Hence, for
and
we have
. This explains
our choice of sign and phase convention above. Indeed, owing to the
factor of
, we have a peak deflection of
, where
is
the cavity length and
the beam energy. Thus, if
is
specified in volts, and the beam energy expressed in electron volts,
the deflection is simply the ratio of the two. As a result, we've
chosen to parametrize the deflection strength simply by referring to
the ``deflecting voltage,''
Next: RFTMEZ0
Previous: RFMODE
Robert Soliday
2005-09-01
